an extrude using two different sketches
I am trying to convert some old autocad drawings into solid models. I am pretty familiar with pro-e, but can't find the function using UG. I am trying to to connect a circle and obround with smooth edges to subtract from a solid body.
The first pic shows the actual part. The second and third pics show the profile of the shape. The forth pic shows what I have in UG (I have the solid body hidden). Fifth pic shows the solid model.
Any help would be greatly appreciated.
Brett
RE: an extrude using two different sketches
What version of NX are you using?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
NX 6.0.5.3
Try using through curve.
insert-mesh surface-through curves.
I set my alignment to "By Points" to tweek the surface when the sections vary greatly.
Jurgen
NX7.5 TCUA 8.3 Win7 64bit.
OK, you should use the Surface Thru Curves...
Insert -> Mesh Surface -> Through Curves...
...and then use the Alignment method 'By Points'.
If you open the attached model and double-click edit it, you'll see how it was constructed,
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks guys, it seems to work. Just took a little while to get the points where I wanted them.
