Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Your site has saved me hours of work that I cannot begin to express my satisfaction..."
Geography
viderde (Mechanical)
15 Jun 12 14:08
I have an 3D IGS file of a part that I need to make into a 2D drawing (either in Pro/E or in AutoCAD) complete with dimensions. It needs to be editable. I need a way to do this without having to actually redraw everthing because it is a very complex part and I do not have all of the necessary dimensions to make a part from scratch. What is the best way to do this? I can't tell if this is easy or impossible...
PS I'm a Pro/E newbie and even worse at AutoCAD so speak slowly haha.
dgallup (Automotive)
15 Jun 12 17:06
IGES is dumb geometry. You can import it into Pro/E but it will just be a lump of geometry. No features, no parametrics. If you are lucky it will come in as a solid. You can make a 2D drawing of it but you will have to create all the dimensions in the drawing. You won't be able to click on a dimension, give it a new value and regenerate the model.
SUPPOSEDLY you can open it in CREO Elements Direct and you can modify it. I have no idea how well that works.
I have no idea what AutoMADS current capabilities are in this regard.
rollupswx (Mechanical)
22 Jun 12 8:19
Can you zip and attach the original IGES file here?
geesamand (Mechanical)
18 Jul 12 20:25
IGES /= editable.
You either have to live with it as static geometry and dimension it in detail using created dimensions / tolerances, or recreate it with parametric features.
Dave
Close Box
Join Eng-Tips® Today!
Join Us             Close
