TeamCenter 8 Save As
I am currently using TeamCenter 8 and NX6. I have an Item with Item Revision A. I also have a New parametric model with drawings of the same design saved as a different Item and Revision. I would like to update the first item with the parametric model and completed drawings as Rev B.
When I do a Save As, NX wants to create a new Item. I want to Save As to an existing Item, but as the next revision. Cloning doesn't work either.
Is there a way to do this in TeamCenter?
RE: TeamCenter 8 Save As
I believe it is called Duplicate Dataset. Try getting a hold of GTAC.
Contains.
duplicatedataset.dll
duplicatedataset.dlx
Another option is to write your own NX Open application to accomplish this, as the NX Open calls will allow you to do what you are asking. It is pretty simple. Just need to encode a file name, and then Save-as to encoded filename.
www.nxjournaling.com
How would I move the drawings over and associate them with the model?
