Low Flow Pump Manufacturers
Hi everyone, I am currently looking for a low flow NGL pump. The flow is 100 gpm; suction P is 175 psi and the discharge P is 405 psi. Our plant is in a rural area (west TX), so we don't have that many choices when it comes to pump suppliers/manufacturers. A lot of the locals have said that they can't do it because of the high differential pressure and low flow. Can anyone suggest a reputable and reliable company that can build an ANSI pump with the above specs?
Thanks for your help and references.
RE: Low Flow Pump Manufacturers
I think FLOWSERVE can provide your desired pump.
For more details or checking out pumps you can log on to Link .
There is an customer version for selection of pumps.
Check it out & contact me further assistance.
Goulds should have a nice selection, 1.5x3-13 LF3196; contact your local Goulds rep.
