Wireless Antenna Advice
Somebody who knows which kind of antenna I could use to
transmit data in a wireless lan across 3 buildings.
I mean I will use an ADSL direct to the wireless access point but the distance between the the source and the client (using wireless PCMCIA cards) is aprox. 492 feet, so what can I do to improve the range.
1)I need to set an antenna only in the building with the access point, just to improve the range?
2)I need an antena in both client and access point buildings
Please some advice about this ......
RE: Wireless Antenna Advice
www.google.com/search?q=pringles+antenna
This one is legendary in the 2.4GHz LAN antenna world - it provides about +15dBi gain. There are other (better) antenna options, but this one is the most famous.
For the client antennas, I would use a small panel or Yagi in the 10-15 dBi range. These also are in the $50-150 range.
Check out http://www.telexwireless.com/wlanfaq.htm for antenna info.
I have another question, I read the article about the pringle antenna so my question is can I use it to improve the range of the signal in the wirelesss access point and not only in the client pcmcia card to my laptop.
This kind of antenna can be used to the tv, radio etc ....????
Forgive my ignorance
