Cooling Device for sampling fluid to analyzer at from 50deg C to-35 deg C
A maximum temp. of 35 degC is the requirement for residual chloride analyzer, i need to cool a brine solution flowing to 6 numbers of .5 inch DN SS tube coming from outside the building with 50 deg C temp to the requirement of 35 deg C.The analyzer is located in a conditioned space of around 25 Deg C inside the building. Can anybody suggest me what sort of mechanical cooling device i can use? I dont have cooling water, chilled water system to cool it, does allowing these tubes to coil/loops will help reduce temp or will give temp diff. around 15 degC.
esong 29
