Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...One of the best run forums I have used in years! ...I like the way the site is organized and your no tolerance of flames..."
Geography
inchy (Geotechnical)
14 Jun 12 11:26
thread261-293009: degree of saturation for organic soils
i have found the degree of saturation of an organic soil sample to be 234%. is it possible for the organic soils? what should be the correct oven drying temperature for organic soils. i have used both 77 and 105 degree celsius. there was not much varation.
fattdad (Geotechnical)
14 Jun 12 12:05
the degree of saturation cannot exceed 100 percent, so we're not talking the same language. Moisture content can vary from 0 to several hundred percent, so maybe that's what you're reporting.
I'd have no problem recognizing that organic soils can have natural moisture contents of 200 percent (or greater). Just saw a report today and noticed a moisture content value of about 190 percent.
Please recognize that soil that's primarily organic matter has a specific gravity of "soil" grains that's much less than soil. Moisture content is weight of water divided by weight of solids. If the solids don't weigh much (and there's a lot of water), you'll get a high value.
Nothing wrong with rechecking your work, your oven and your proceedure, but you're likely on the right track.
f-d
¡papá gordo ain’t no madre flaca!
molerat2210 (Geotechnical)
15 Jun 12 13:24
I believe ASTM D 2216 says use 40 degree C for moisture content if suspected organics.
Provide comparison of oven dry liquid limit to air dry liquid limit per ASTM D 4318 to determine if soil if organic.
Classify organic soils per D 2487.
Provide an organic content test by ASTM D 2974 as additional back-up.
Kpaudel (Geotechnical)
3 Oct 12 10:49
What about Specific Gravity of Organic Soil?
reyv (Civil/Environmental)
9 Oct 12 11:01
fattdad is correct. You can't exceed saturation of 100%. You are most likely talking about moisture content, which can be in the order of 200% (this is typical for peat).
Rey Villa, MS, PE
http://geotech-apps.com
Close Box
Join Eng-Tips® Today!
Join Us             Close
