Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
...I enjoy spending time on it for personal growth (I learn from the questions I don't answer, and I reinforce/stay sharp on the topics I do answer), and to give back to humanity at large...
Geography
frfouqa (Mechanical)
14 Jun 12 10:48
I 'm looking for an information.
I try to compute a blind flange 8" 300lbs (from the B16.5) as a flat head drilled with a 40 mm hole diameter.
The american standard say that the minimum thickness is tf=39.7 mm and the raised facing is 2mm.
To know if my blind flange is adequate under pressure, can i consider the thickness of the flange is 39.7 mm or 41.7 mm to do calculation ?
And gnerally speaking, can we consider the thickness of the raised face for calculation?
Thank you for your answer.
SnTMan (Mechanical)
14 Jun 12 11:15
frfouqa, compute it how?
See ASME B16.5, Para 6.4 for facings dimensions.
See ASME Sec VIII, Div 1, Apx 2, Fig 2-2, General Note (b) for this Code.
Mike
Helpful Member!  doct9960 (Mechanical)
14 Jun 12 11:52
frfouqa,
You don't need to perform pressure calculations if the hole is just 40mm.
The B16.5 pressure-temperature of your 8" Class 300 blind flange is still valid if the corroded I.D. of the hole does not exceed 88.9mm. Check Table 6 of ASME B16.5.
15 Jun 12 3:41
Thanks for you answer.
I find ine the general note of the ASME (as SnTMan has suggested to me) that if the facing thickness is greater than 1.5 mm, i Can't take it.
Close Box
Join Eng-Tips® Today!
Join Us             Close
