Where is extract curve nx8
Where is the extract curve command in nx8.
Not the extract virtual curve command.
Thank you
Thank you
NX 3.0 NX 5.0 NX 7.5
HP Mobile Workstation 8730W
XP Pro
RE: Where is extract curve nx8
It is under Insert- Curve from Curve - Extract, the line above Extract Virtual Curve.
Else use the command Finder, it will expand the dialog.
Thank You.
How do i add the command to the Curve from Body dialog
XP Pro
Frank.
See picture.
Or if you desire to modify the current role, RMB somewhere on the icons, - customize.. commands tab, scroll the left pane to find insert - curve from curves, pick extract from right pane and drag drop into/onto the place in the main menu system where you want it. Then RMB in the "whitespace" besides other roles "New User Role"
Help -> Command Finder
And enter what you are looking for
but try the "advanced with full menus" role thing first
Thank You for the help.
NX 3.0 NX 5.0 NX 7.5 NX 8.0
XP Pro
