Polishing UHMW
Polishing UHMW
Polishing UHMW
Can anyone recommend a polish/technique to get a very smooth surface on a UHMW? Ideally something easily obtainable and not requiring a particular skill.
The part is a mold and I'm hoping a smoother surface will improve release of shore A 40 silicone parts. Currently the surface has machining and sanding marks in it and it's not releasing even with various mold release agents.
Thanks!
Jon C.
RE: Polishing UHMW
Wave a flame over it?
RE: Polishing UHMW
Can you post an image of the cavity or at least it's profile sketch?
Is it an open (split) cavity?
The finishing process will be determined or restricted by accessibility to the cavity surface.
RE: Polishing UHMW
High speed buffing wheel with a generous amount of pressure applied? Heat from friction should soften the material and help polish, especially at the rough surfaces. Flame is not a bad idea but would only gloss over the grooves, not necessarily eliminate them.
RE: Polishing UHMW
The very best way to get a smooth finish on UHMW is to not make it rough in the first place.
RE: Polishing UHMW
You can't polish UHMW.
You can waste a lot of money trying, of course.
Instead, spend the money polishing the tools that cut the cavity, bring their edges to razor sharpness, and never use them to cut anything else.
Then machine the cavity in a few passes, with the last/finish pass being not less than .003" (or maybe .005" or even .010", depending on the material particulars).
I.e., you can't sneak up on the size you want in UHMWPE, with skim cuts or abrasives; you have to cut right to size while producing a chip that is fairly strong and thick.
Mike Halloran
Pembroke Pines, FL, USA
RE: Polishing UHMW
Just found this, first page of google results for "polishing UHMW"
http://www.connecticutplastics.com/qa/plastic-poli...
"I have a transfer mold for pulp & paper that requires a smooth finish to prevent sticking. The material is white UHMW. Is this material suitable for polishing? If not, can you recommend another material?
UHMW can be polished through buffing. Depending on the plastic part configuration, we can achieve a high finish."
Now how well it works is another issue and I am not making any claims about that, but this is your best bet. Before scrapping the mold and making a new one, it is worth a shot to take an angle grinder with a buffing wheel to it.
One more off the cuff suggestion, buff it with oil in an attempt to impregnate the plastic slightly. Probably won't work all that well but again, could be worth a shot.
RE: Polishing UHMW
The mold's built up from 2" sheets and it's not split so not much access to internal surfaces (see attached).
I managed to get a nice shine on a small test area using 600 thru 1500 wet sanding then coarse and fine acrylic 'scratch remover' polishes followed by red rouge on a drimmel tool. Lots of labour :/
Has anyone actually tried flame polishing UHMW? I've heard it's quite easy to damage/oxidise the surface by going just a few degress beyond melting point.
RE: Polishing UHMW
Is there no draft on those faces?
You wouldn't have to use an actual flame. Other heat sources would also work, and may be more controllable.
RE: Polishing UHMW
Yup there's draft.
I guess I'll experiment with a heat gun on some samples..
RE: Polishing UHMW
OK heat gun failed. On max temp it was putting way too much heat into the (sample) material and warping it before I could get the surface to melt. Melted surfave was nice and shiny tho..
RE: Polishing UHMW
My idea would be to machine the orignal as a positive using a material you can polish, and then make a casting of it using melted UHMW. That casting would then become your mold.
I have no idea if UHMW can be melted and remolded, and then retain all of its original properties.
Joe Dunfee
RE: Polishing UHMW
I thought you could only extrude UHMW. Why not use something more conventional for the mold like steel or aluminum?
RE: Polishing UHMW
I'm making prototypes in the mold and can't wait weeks for a replacement, I need to make this one functional.
FYI UHMW is machinable, about as slippery as teflon and one of the cheapest plastics out there (1/4 the cost of aluminum(?)).
So..it seems a flame is all that's left to try (or possibly a really hot heat gun?). Any ideas on what type of flame?
RE: Polishing UHMW
A propane torch is suitable for flame polishing. I'm not sure that it will work for UHMW because the high molecular weight means that the polymer never truly melts and becomes fluid. Flame polishing works because the surface will form a fluid film that levels-out imperfections due to surface tension. The heating has to be intense to melt the surface film without transferring significant heat into the bulk. You will get some oxidation. This same process is used to treat polymer surfaces to improve bonding.
