Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...with companys cutting back on training, lack of true support by makers of software, the forums are a great tool in your cyber-toolbox...."
Geography
CCARDINAL (Industrial)
13 Jun 12 15:40
HELLO ANYONE WHO READS THIS,
I'M RUNNING A MAZAK TURBO X-48 1000 WATT LASER. I'VE GOT A JOB LASER CUTTING 3 HOLES THROUGH 1 WALL INTO 112" STAINLESS AND GALVANIZED TUBING.THE CUSTOMER DOESN'T WANT ANY MARKS ON THE INSIDE OF THE TUBE. THE PAST FEW RUNS IVE STUCK .187 THICK HRS BAR ON THE INSIDE TO PREVENT MARKS. AFTER SO LONG, THE TUBES EVENTUALLY BURN THROUGH. I'M WONDERING IF USING BRASS OR ALUMINUM WOULD BE BETTER. ANYONE HAVE ANY SUGGESTIONS? THANK YOU!
HenryRollins (Industrial)
13 Jun 12 15:48
What is the diameter of the tube you are cutting? I have used rebar with anti spatter in the past when requested that no bur or slag to left in the tube.
-HR
14 Jun 12 12:05
1.375 INCHES IS THE INSIDE DIAMETER OF THE TUBE.
Helpful Member!  HenryRollins (Industrial)
14 Jun 12 12:56
have you tried to pulse cut the holes?
Helpful Member!  krugtech (Industrial)
15 Jun 12 9:29
rebar is a cool idea. sucking on the end of the tube w a huge blower also helps, it pulls the spatter down the tube just have a spark arrestor
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
18 Jun 12 18:52
havent tried pulse cutting yet. i like the rebar idea. havent had a chance to try out the ideas yet but i sure appreciate the advise.
Close Box
Join Eng-Tips® Today!
Join Us             Close
