Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I have to add my thanks and appreciation for your wonderful site... People who frequent the site are the two best things - nice and smart..."
Geography
ntweisen (Mechanical)
13 Jun 12 13:38
In sheet one in column A I have a list of 2000 names (some of them repeated) and column B lists each person's score percentage. In sheet 2, in column A I list each person's name exactly once and in columns b, c, d I want to list their first, second, and third best percentage. I know I can use the LARGE function to get a best score from a list but I am not sure how to make it so the function only appilies to the individual listed in sheet 2 column A. Does that make sense?
Thanks for your help!
http://excelspreadsheetshelp.blogspot.com - http://scripting4v5.com
MintJulep (Mechanical)
13 Jun 12 13:59
Look into how to use Pivot Tables.
LiteYear (Computer)
13 Jun 12 19:26
You could also use array values to return you an array of matches to a lookup, then perform a LARGE on that.
http://www.get-digital-help.com/2009/10/25/how-to-...
IDS (Civil/Environmental)
14 Jun 12 19:37
The formula below is adapted from an article on Chop Pearson's site: http://www.cpearson.com/excel/ArrayFormulas.aspx and is a bit neater than given in LiteYear's link.
If the names are in B6:B105 the scores are in C6:C105 and a selected name is in E6 then:
(IF($B$6:$B$105=$E6,$C$6:$C$105,FALSE)
will return an array of 100 items containing either a score for the selected name or FALSE.
You can then wrap the Large() function around that:
=LARGE(IF($B$6:$B$105=$E6,$C$6:$C$105,FALSE),F$5)
where F5 contains the rank you want.
Note that because this is an array formula it must be entered by pressing "Ctrl-Shift-Enter". If you just press "enter" it returns 0.
A sample spreadsheet is attached.
Doug Jenkins
Interactive Design Services
http://newtonexcelbach.wordpress.com/
Helpful Member!(2)  IDS (Civil/Environmental)
16 Jun 12 1:08
18 Jun 12 10:35
Thanks for the help and the excellent write up!
18 Jun 12 21:01
ntweisen - Glad to help. I've added a bit more to the blog post in response to a comment, that may be of interest.
Doug Jenkins
Close Box
Join Eng-Tips® Today!
Join Us             Close
