[NX 7] Through curves
3
I'm trying to create a path cable with through curves command, but I'm not able to reverse the flow direction of the second curve.
See attached picture.
The best is create a 3D spline and after the tube command, but sincerely I'm not able to create a spline attached to the two plane surfaces with the tangent direction to the axis cable.
Spline tool for me is at the moment an obscure command.
I attach also the result obtained with other system CAD.
Thank you...
Using NX 8 and TC8.3
RE: [NX 7] Through curves
- So what do you want from us ?
help on creating the spline ?
May You send the prt file in NX with the wrong through curve command applied?
Frank.
Your problem has NOTHING to do with using Surface Through Curves since that's the WRONG function to be using in this situation. What you need to do is first learn to create the proper curve(s), in this case you might wish to start with a bridge curve or if you need more control over the shape, then a series of splines/arcs/lines to define the path of your 'cable'. Once that's done then use the Sweep -> Tube function to create your cable.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks to all,
some commands are not fully understood, so I thought to wrong in the Through Curves and as I had guessed, is not command to use.
I tried using the bridge command, but I'm not able to set a start tangent to the cable and the opposite end in the connector.
Do you have a short video?
The top, I would make a spline, but even here I lack the knowledge of the command.
A video to create a spline for 3 points would be useful.
Thank you...
Bridge curve is used to connect 2 curves; create a short line along the axis of your connector (if extract virtual curve is available in NX7, this is a good use for it) and then use bridge curve to connect your 2 lines.
www.nxjournaling.com
BTW, when we said 'Bridge' we were referring to Bridge Curves, NOT Bridge Surfaces.
I hate to say this, but if at this point in time (I know you've been using NX for at least 2 1/2 years since I personally have been responding to your inquiries here since November, 2009) you still feel that you need someone to create for you "A video to create a spline for 3 points..." before you can continue with this model, then you really need to consider taking some formal training. These message boards are NOT, and never will be, a substitute for being adequately and properly training, PERIOD!
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John,
I'm talking about curve bridge.
NX cover more environments and it's impossible to know everything.
My job is project automatic machines and some command are not covered or covered sometimes in one months.
Remember that the company pay me to project and not remain updated to CAD evolution or to know each NX command.
What I know on NX is under the web and from this site, outside the hour job and loose my spare time, only to know NX better.
I understand that Eng Tips in not the site to make courses, but I didn't ask to understand how to make pattern (title block template), but only make two short video to cover the bridge curve and spline.
Thank you...
3
Cuba,
here's a little video. A lot of zooming and panning since i made the screen area small to keep the video small.
I used a spline,not a bridge curve, since i felt i needed an extra point along the curve.
once I have selected the point and G1 ( Tangency) i need to pick one of the points again to reverse the tangency direction, then 2 arrows appears, one of the two arrows allows "reverse direction by double click" ( I am trying on the wrong one in the video...)
The video is captured using Snagit, if it doesn't replay, download the codec from techsmith.com
Tomas
Toost,
the video is clear and perfect.
Thank you.
Thank you...
