Creating a pulsating water flow with a paddlewheel.
I am trying to make a prototype of a new kind of pulsating machine similar to the pulsations and water pressure seen in a Water Pick(Oral Irrigation) device. I am going to try to use a paddle-wheel mounted inside a water tight cylinder that barely circumscribes the paddle-wheel. The entering pipe will be positioned parallel to the exiting pipe and will be located near the edge of the paddle-wheel for the larger moment force. There will also be a one way air valve attached to the cylinder. Now I think the device will pulsate, but I don't know if it will because of temporary pressure change when the paddle-wheel blocks the exit or if it will because of air being sucked into the system. Anyone have any advice??
RE: Creating a pulsating water flow with a paddlewheel.
If it ain't broke, don't fix it. If it's not safe ... make it that way.
http://www.google.com/patents?id=hTsvAAAAEBAJ
http://www.google.com/patents?id=oaIhAAAAEBAJ
But those don't "pulsate" when they add pressure to a system, why would expect the waterwheel to pulse? If the wheel is restricted (by a brake or by friction) wouldn't that be a wear point or fouled by deposits and scum/biologics buildup?
http://en.wikipedia.org/wiki/Peristaltic_pump
Lyle
