Reducing fitting for concentric shafts?
I need to clamp a dial indicator with a 3/8" stem to a pipe containing a piston. The dial indicator will measure the position of the piston. Concentricity is critical to the measurements being taken.
The size of the pipe will vary set up to set up (~.5"-1.5").
If anyone knows of any stock fittings for this application, it would save the time of custom machining one.
Thanks!!
Thanks!!
