Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...keep up the good work with this forum, I think this is the best one around. ...you actually try to help people learn for themselves. ...I commend you on providing a very good, open learning atmosphere, where usually egos are left behind..."
Geography
EChristensen (Structural)
12 Jun 12 13:04
Looking for interpretations of AISI S213-07 Lateral Design regarding flat strap blocking used at the edges of sheet steel sheathing.
Is it your interpretation that when you use flat strap blocking per section C2.2 item 8, that you do not need to take the 30% reduction from section C2.2.1 item 4? It seems to me that the reduction is probably due to buckling of the sheet steel sheathing panels, since overlapping the panel edges is just as effective at transferring the shear as blocking, but is susceptible to buckling.
Flat strap blocking; still take 30% reduction, yea or nay?
Close Box
Join Eng-Tips® Today!
Join Us             Close
