Struggle to open big assembly..
All,
I've sometime struggle to open big big assembly - sometimes I do not get luck to open them and gave me lots of issue and sometime crashes the system.
I always use load options to open assembly quickly but still I get frustrate sometimes open assembly. Do you have any shortcut/tricks to open assembly other than this? Please advise.
Arvind
Mechanical Engineer
UG 7.5.5.4 & TC 8.3
"People can take everything from you except luck"
RE: Struggle to open big assembly..
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit (Intel(R) Xeon(R) CPU X5650 @2.67GHz)
24.0 GB
NVIDIA Quadro 4000 + NVIDIA Tesla C2050
Aj
Mechanical Engineer
UG 7.5.5.4 & TC8.3
In case you run 32 bit, try open the same assembly on a 64 bit computer. It might be the RAM limit you are interfering with.
Best regards,
Michaël.
24.0 GB
Aj
Mechanical Engineer
UG 7.5.5.4 & TC8.3
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I'm running 64-bit Xp machine..We use this intentionally to give good performance.. Is that you're asking me?
Aj
Mechanical Engineer
UG 7.5.5.4 & TC8.3
"Error recovery completed for the following error: An attempt was made to create a link between objects in different parts".
Aj
Mechanical Engineer
UG 7.5.5.4 & TC8.3
The way to check is to read the start of the NX logfile, it should be similar to the example below
See last line :
Information listing created by : Tomas
Date : 2012-06-12 18:38:48
Current work part : C:\Users\.....
Node name : xxxx
*** C:\Users\Tomas\AppData\Local\Temp\....
*** system log created by Tomas on Tue Jun 12 18:03:51 2012 W. Europe Daylight Time
Node Name :- xxxx
Machine type :- GenuineIntel Family 6 Model 10 Stepping 7, Intel(R) Core(TM) i7-2820QM CPU @ 2.30GHz
OS :- Windows NT (x64) 6.1 (Workstation) (Build 7601: Service Pack 1)
:- 64 bit software version
Aj
Mechanical Engineer
UG 7.5.5.4 & TC8.3
This is a copy from the PR list in NX6 but you are using NX 7.5.5.4? Have you installed a MP on the NX installation? If not try installing MP2 and see if the problem is solved.
Best regards,
Michaël.
24.0 GB
Info -> part history
Thanks for your valuable input.. I am able to resolve that issue, but my intent was posting was concern I just needed to know is there any shortcut / tricks to open big big assembly.
Aj
Mechanical Engineer
UG 7.5.5.4 & TC8.3
