jraef (Electrical) |
12 Jun 12 12:24 |
The first link in the FAQ that Pete showed is a direct copy from NEMA MG-1, the design guide for AC motors. Siemens for the most part designs their motors to be able to meet specs anywhere in the world, so yours will likely be designed to meet that, but only Siemens can definitively answer that question. As to DOL vs Star-Delta, as I was taught it makes no difference in terms of the starting capability of the motor, the energy it takes to accelerate a load from a dead stop is fixed. All that changes is that in reduced voltage starting, you trade the peak height for the time width on that energy curve, but the area of the curve, which determines the heat in the motor, remains constant. I agree that there are other nasty transient consequences to Star-Delta starting and I abhor it as a starting method, but I don't think the effects of those transients cumulatively increase the overall acceleration energy, or at least not significantly. But neither will Star-Delta help out, so there is no good reason to use it. If you want to use a reduced voltage starting method, use a Solid State Starter. Still, no difference in the thermal effects on the motor, but it is a better way to do it. the only starting / control method that does alter the thermal characteristics is to use a VFD. With a VFD you can accelerate without ever exceeding the motor nameplate FLA, assuming you can take as long as necessary to do so. This is because with a VFD you are always only applying the acceleration torque that is absolutely necessary, there is no excess energy in the motor. thermally, there are other issues with using a VFD that need consideration and there are a myriad of other energy related issues that get added to the mix, some good, some bad. But that is one way to increase the number of starts-per-hour. "Dear future generations: Please accept our apologies. We were rolling drunk on petroleum." — Kilgore Trout (via Kurt Vonnegut) For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies |
