guidance for sheet metal repairs
hello.... i have been working on flight lines in military as an aeropsce engineer for 3 1/2 years. now i v been sent to a depot level activity where suddenly the prority has been changed from systems to structures. though manuals give almost every thing to mos of the common solutions; nevertheless, owing to the lack of past experience, i am finding difficulty in understanding the engineering behind even simple repairs, wat to talk about bigger complex repairs.....
can some body guide m what course of action i need to grip on.....
thanx
thanx
RE: guidance for sheet metal repairs
AC 43.13 (Advisory Circular Forty-three-thirteen)
AC 65.12, Airframe and Powerplants Handbooks, 3 volumes
Also consider flipping through the product catalogs for commercial aviation suppliers, such as Aviall and Aircraft Spruce, whether they apply to the aircraft you're dealing with or not. For a flavour of the general-aviation world. You didn't specify if you're working with transport or private aircraft. Two different modes of operation there.
If you want more reading material than that, try "Jeppesen" publications.
STF
my sqn used to fly P3s and still i m in a p3 facility...... but where every a/c is on jack and stripped... so its way different
my actual concern has been finding the way up for out of manual repairs......
i will be going for the course at boeing or may be airbus,whereso ever i get nominated for, but till that time...... its a difficult scenrio. so as to gtrab oto the basics, i v started with making a sense into the in SRM repairs....
SRM repairs are a bunch of canned solutions.
AC43-13 gives you some guide-lines for making repairs, very generic and sometimes contra-indicated (ie, i wouldn't do some of the things they suggest).
if you're still dealing with P3s, then you won't have entered the damage tolerance world, but you still need to consider fatigue effects of repairs.
the Boeing Liasion stress course (put on by U.Kansas) is a good starting point for analyzing repairs.
do you have anyone there to talk to ? very unfortunate for you if you don't !
I assume they replace the AC65 documents.
In theory, there is no difference between theory and practice; experience suggests that in practice, there is.
You are right, they do replace the AC-65 Books They are available as PDF's from FAA.gov ( Free download)do not get sucked into paying people like Scribed for these.
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them. Old professor
Regarding the beloved AC43-13, remember it is "acceptable" data, and not "approved" data.
None of this matters if you're still in the military, but will serve you later, in the civilian world.
Spent my life doing What You are doing... only for the USAF.
I have accumulated a 1/2-ton of liaison training documents... including several from USN and USAF Depot Sources and several companies... for both structural and menchanical repair design. I've recieved and hoarded my info recieved piece-meal thru the years. Unfortunately there seem to be no library for this sort of training material... since there are issue with proprietary rights. The problem with this forum is that it is deliberately hard to exchange these documents... for a slew of good, and bad/sad, reasons. I wish there was an anonymous site for posting this type info... but then the "bads guys" [competitors, such as chinese, Iranians, etc] could also have access" [or would steal access to it]. This stuff is gold... how we do our work thru the years. The company I work for now is especially jealous of this type intellectual property.
Ask Your counterparts and have them ask their friennds, etc, and You may be surprised what comes out of the wood work.
Also (duhhhh), attending one [actually as many as possible] engineering skill training courses, getting to know and be trusted by others... and never letting a good reference ever slip thru Your fingers... are starting points.
Gotta go back to work.
Regards, Wil Taylor
Trust - But Verify!
We believe to be true what we prefer to be true.
For those who believe, no proof is required; for those who cannot believe, no proof is possible.
