Horizontal (PC) or Overhead position (PE)?
Guys,
we are having a little debate in work with relation to weld positions. The attached doc shows the weld prep, which is a two sided butt weld, which is back-gouged after first few passes. The weld is approx 6 feet off the ground. we reckon the position is horizontal, our client reckons it is overhead. The client is not being awkward, and we have a procedure which will cover us anyway, but would like some other opinions anyway
regards & thanks
Declan
regards & thanks
Declan
RE: Horizontal (PC) or Overhead position (PE)?
Details should be in there to provide you guidance.
The 2011 edt also contains some new positions due to interpretation discussions
that occured amongst her users in the previous edition, regarding certain positions.
