NX6.0 auto ordinate dimensioning
Is it possible to do auto ordinate dimensioning in NX6.0 as one can do in ProE? Thank you!
RE: NX6.0 auto ordinate dimensioning
If you look at the image below, here's an example where all I had to do after placing the view on the drawing, was to define the 'origin' (the 0,0 point), which was a single screen pick, for the Ordinate Dimension Set, define the 'margins' so as to limit the extension of the Dimensions, again requiring only a single pick. Now all I had to do was 'area select' using the cursor, the arc center points, and hit OK:
http://i608.photobucket.com/albums/tt169/jbakersr/...
I think that's about as 'automatic' as one would expect it to be.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I'm having trouble getting this technique to work. But first, the files I'm wanting to use this technique on already have a ordinate dimension origin in them which was there when it was saved to be a template. Can some one tell me how to delete this origin? I want to remove it from this template.
NX7.5
James
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Now to the original subject of this thread & probably another dumb question. Once I've set the origin & the margins I can't figure out how to area select the objects. I left click, hold & drag but my cursor has the red crossed circle no symbol & no selection box is created by the drag. What am I doing wrong?
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
