Import lines to NX4
Import lines to NX4
Import lines to NX4
Hello every body,
I would like to import lines to a cad model. I have in a worksheet the lines defined by points (x,y). I know how to import those points, but I can´t import a line. It´s possible? for import the points I´m using "file2points" file.
Thanks!!
RE: Import lines to NX4
Would that be the file2points grip program (.grx) or the journal program (.vb)?
www.nxjournaling.com
It´s the journal program (.vb)
Inside of NX's database lines are defined simply as two points. So if you have the points imported, that all that you need. Granted, you will now need to actually create the 'line' objects, but you already have the data needed for the job.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Here is a quick & dirty edit that will import the pairs of points in the file as lines. This may not do exactly what you want, but should serve as an example of how to create the lines from your given points.
CODE
Option Strict Off
Imports System
Imports System.IO
Imports System.Windows.Forms
Imports NXOpen
Module Module1
Sub Main()
Try
Dim openFileDialog1 As New OpenFileDialog()
openFileDialog1.Filter = "txt files (*.txt)|*.txt|All files (*.*)|*.*"
openFileDialog1.FilterIndex = 1
openFileDialog1.RestoreDirectory = True
If openFileDialog1.ShowDialog() = DialogResult.OK Then
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim sr As StreamReader = New StreamReader(openFileDialog1.FileName)
Dim line As String
Dim startPoint As Point3d
Dim endPoint As Point3d
Dim i As Integer = 0
Try
line = sr.ReadLine()
While Not line Is Nothing
'Dim pt As Point3d
Dim delim As Char() = {","c}
Dim strings As String() = line.Split(delim)
endPoint.x = Double.Parse(strings(0))
endPoint.y = Double.Parse(strings(1))
endPoint.z = Double.Parse(strings(2))
If Not IsNothing(startPoint) Then
'create a line from startpoint to endpoint
workPart.Curves.CreateLine(startPoint, endPoint)
End If
startPoint = endPoint
'Dim p As Point
'p = session.Parts.Work.Points.CreatePoint(pt)
'p.SetVisibility(SmartObject.VisibilityOption.Visible)
End While
Finally
sr.Close()
End Try
End If
Catch E As Exception
MessageBox.Show(E.Message)
End Try
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image when the NX session terminates
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
End Function
End Module
thanks!! I will go to try! I´ve never used the journal before, so I have to try it.
In what format should be the coordinates in the file?
My file looks:
264.560,-259.448,-18.276
263.969,-259.748,-18.302
263.374,-260.040,-18.328
262.776,-260.325,-18.354
262.174,-260.602,-18.380
266.889,-258.178,-18.274
and the result: Input string was not in a correct format.
kukelyk
Your test data appears to be in the correct comma delimited format. I ran a test on your posted data and it worked. I suspect this is only a small portion of your data; does the data file have headers or blank lines? If so, they may cause problems. The journal uses Double.Parse to convert input to numbers, if there are other non-numeric characters in the file it may also cause such an error.
After I removed all empty lines, the error is the same..mad
kukelyk
Can you post the input file that is giving you problems?
With the exception of an extra line from (0,0,0) to the first point in the file, it works fine for me.
What language is your computer set to use? I suspect it is a .NET setting that is interpreting your input differently than what my computer is using (reference thread561-315066: creating multiple spheres on imported coordinates for another example). If your computer language is something other than English, perhaps we can "borrow" petulf's fix from the other thread.
Below is the updated code to get rid of that extra line.
CODE
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Module Module1
    Sub Main()
        Try
                Dim line As String
                Dim startPoint As Point3d  = nothing
				Dim firstPass as Boolean = True
                Try
 'Dim pt As Point3d
                        If firstPass Then
							firstPass = False
						Else
                        End If
 'Dim p As Point
                    End While
                Finally
                    sr.Close()
                End Try
            End If
        End Try
    End Sub
    End Function
End Module
Thanks, but still not resolved, the same error..
CODE --> TCL
Imports System
Imports System.IO
Imports NXOpen
Module Test
    Sub Main
                Dim session As Session = Session.GetSession()
                Dim line As String
                    line = "264.560,-259.448,-18.276"
                        Dim pt As Point3d
                       ' Dim delim As Char () = { ","C }
                        Dim delim As Char () = { "," }
                        Dim strings As String () = line.Split(",")
session.ListingWindow.Open
session.ListingWindow.WriteLine( strings(0) )
session.ListingWindow.WriteLine( strings(1) )
session.ListingWindow.WriteLine( strings(2) )
                        pt.x = Double.Parse(strings(0))
                        pt.y = Double.Parse(strings(1))
                        pt.z = Double.Parse(strings(2))
                       Dim p As Point
    End Sub
End Module
gives as a result:
in the info window:
264.560
-259.448
-18.276
error message:
System.FormatException: Input string was not in a correct format.
at System.Number.ParseDouble(String value, NumberStyles options, NumberFormatInfo numfmt)
at System.Double.Parse(String s)
at Test.Main() in C:\Users\kkukely\AppData\Local\Temp\NXJournals3400\journal.vb:line 23
What??
the 23th row is:
kukelyk
What language/regional settings is your computer set to use?
In win xp this can be found in the control panel under "Regional and Language options", I'd guess it is in a similar location for more recent versions of windows as well.
Really, the problem was in this "Regional and Language options". When I set it to en-US, the Double.Parse runs correctly.
kukelyk
Other problem: it is possible to create points in WCS instead of absolute?
kukelyk
Other problem: is it possible to create points in WCS instead of absolute?
kukelyk
This version should work regardless of your regional setting and it will output the lines relative to the WCS.
CODE
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Imports NXOpen.UF
Module Module1
	Dim ufs As UFSession = UFSession.GetUFSession
	Sub Main()
		Try
				Dim line As String
				Dim USculture As system.globalization.CultureInfo = New System.Globalization.CultureInfo("en-US")
				Try
						endPoint.x = Double.Parse(strings(0), USculture)
						endPoint.y = Double.Parse(strings(1), USCulture)
						endPoint.z = Double.Parse(strings(2), USCulture)
						endPoint = Abs2WCS(endPoint)
						If firstPass Then
							firstPass = False
						Else
						End If
					End While
				Finally
					sr.Close()
				End Try
			End If
		End Try
	End Sub
'Date:  11/18/2010
'Subject:  Sample NX Open .NET Visual Basic routine : map point from absolute to wcs
'Note:  GTAC provides programming examples for illustration only, and
'assumes that you are familiar with the programming language being
'demonstrated and the tools used to create and debug procedures.  GTAC
'support professionals can help explain the functionality of a particular
'procedure, but we will not modify these examples to provide added
'functionality or construct procedures to meet your specific needs.
	Function Abs2WCS(ByVal inPt As Point3d) As Point3d
		Dim pt1(2), pt2(2) As Double
		pt1(0) = inPt.X
		pt1(1) = inPt.Y
		pt1(2) = inPt.Z
		ufs.Csys.MapPoint(UFConstants.UF_CSYS_ROOT_COORDS, pt1, _
			UFConstants.UF_CSYS_ROOT_WCS_COORDS, pt2)
		Abs2WCS.X = pt2(0)
		Abs2WCS.Y = pt2(1)
		Abs2WCS.Z = pt2(2)
    End Function
	End Function
End Module
Great, many thanks
kukelyk
