Grain boundaries
Grain boundaries
Hello all,
After grinding a 12" 25/20 centrifugal casting to a 10 Ra, the surface appearance of this tube looks uneven in color(light and dark areas). It has been explained to me that this is a reflection of the grain boundaries? Is this true because of the steel mixture being less homogeneous.
Thank you in advance for your answers.
Doug
Doug
RE: Grain boundaries
_____________________________________
"It's better to die standing than live your whole life on the knees" by Peter Mayle in his book A Good Year
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
Plymouth Tube
