Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I have found your site brilliant. What makes it good are the people that contribute to the site..."
Geography
mpsmps (Petroleum)
11 Jun 12 4:53
Dear all,
I recently experimented silica contamination of semirigen platforming catalyst. Silica comes from antifoaming agents used upstream. I'd like information relevant to criteria followed for monitoring pick up and breakthrough, if any, from upstream hydrotreating unit.
Luca
RefinerLink (Petroleum)
5 Aug 12 13:04
Couple of tips for you:
- monitor and manage the amount of antifoam used in upstream coker unit
- install a silicon guard layer as top bed of your hydrotreater catalyst
- measure silicon level in your feed on a routine basis
- perform routine calculations of silicon loading, and pro-actively changeout your hydrotreater catalyst bed
The key point is to be pro-active with your hydrotreater catalyst changeouts. Reformer catalyst is a lot more expensive than hydrotreating catalyst, so don't run the risk. You do NOT want any breakthrough, so having robust monitoring calculations on silicon loading in your HDT is important.
Also, if you process any synthetic crudes in your refinery, measuring feed quality is important since they may change depending on operations at the crude upgrader.
http://www.refinerlink.com
Close Box
Join Eng-Tips® Today!
Join Us             Close
