Need connectiona dvice: I beam to vertical hollow section
See attached sketch:
I need to attach a horizontal I-beam (point load in the middle = 2000 N, length = 4 m) to two vertical members with a hollow section of 120/40/3 mm.
This is a home project, and I'm using what I have lying around, so I'd prefer using these hollow sections but if what I suggest in the attached sketch isn't really feasible, please feel free to advise.
The setup is symmetric, and the vertical members will be attached to both walls (the walls are made of lightweight bricks, so I can't put fasteners in 'em to hold up the horizontal beam).
I don't know how bolted connections are designed for this type of combination, so don't shoot me if I'm thinking totally wrong about this one...
as for the drilled and tapped holes, I'd drill the plates first (all four in one stack), have two of 'em welded on the vertical members, drill through the 3mm of wall thickness, and thread them. in that order. + drill again with a bigger drill for the clearance holes, and have them welded on the I beam.
your opinions on this connection please?
RE: Need connectiona dvice: I beam to vertical hollow section
Use a 3/8" plate welded to the face of the HSS... of can you rest the beam on the HSS and bolt...
Dik
but I don't understand your following comment: (HSS = hollow structural section, right?)
See attached sketch, that's what you mean?
If so, how to fasten the angle iron to the vertical members? Bolting or welding?
thanks in advance...
For 1/8" tube, you can use a 1/8" fillet weld for connection or possibly 3/16 (4mm). Some codes do not recommend using a weld greater than the thickness... CIDET research indicates that goint 15% or so greater provides weld capacities similar to full penetration welds.
With the small loads, welding should not be an issue.
Dik
I'll do it that way (another sketch...).
One last question: cap plate thickness = ?
3mm (1/8") will be too thin I guess?
Would 1/4" be good?
Dik
i'd rather see the attachment to the column being symmetric around the column NA.
you could weld an angle to provide a step for the I-beam to sit on.
Dik
Unless I'll find hollo-bolts here, I can't really fasten the beam on the capplate.
As I only need 4 of those bolts, I doubt I'll find small quantities for sale.
@ ukengineer58: thanks for the tip, I didn't know they existed. It's good to know.
@ dik: thanks again.
if the I-beam can't sit on top of the column, can you weld a bracket to the column that'll provide a rest for the I-beam ?
if the I-beam can sit on top of the column, why can't you bolt symmetrically about the column ? (your pic shows fasteners only on one side of the column, why not both sides ?)
if the I-beam flange is wide enough, why not just weld it to the column ? if it isn't, why not weld a plate to the I-beam flange to make it wide enough ?
I-beam will sit on top of the vertical HSS (which will have a cap plate welded on top of it).
All the way until it's also against the wall (see explanation in first post).
because the HSS will be bolted against a wall, I only have access at the "open" side.
why not weld the beam directly onto the column ? yes, i know the beam is narrower, so weld a plate on the beam's lower flange. the idea should be to get the most direct loadpath from the beam to the column, yes?
the two bolts into the plate, offset from the column, look really (IMHO) ugly. could you tap the holes in the plate and so bolt within the hollow column ? you could add a couple holes to the plate and weld a couple of bolts so their threads protrude.
there are many ways to skin this cat, but IMHO the 2nd pic (of the plate) is possibly the most torturous.
see first post. the HSS transfers the load to the foundation.
Needs to be bolted for erection reasons. Can't weld in situ. Can't place the welded construction in one piece.
appearance is not important. the design (and safety and such) of course is.
I could do that, but that means a 1/2 inch or thicker plate has to be welded to a 1/8 thickness HSS.
Which is also not an ideal solution.
I would gratefully receive a better solution.
2nd attachment has an angle iron, third has a cap plate drawn ?
with the cap plate it spreads the load a bit more.
Both their primary purpose is to fasten the bolt in position. The bolting does not serve to act as a load path.
@ CANEIT: Cannot do. I don't know the translation, but see attachment.
