Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...These forums are an excellent source and example of the way people can help each other..."
Geography
Saravanankumarasamy (Materials)
9 Jun 12 21:14
Dear sir, what's difference between annealing& stress relieving. Is it both same?When we go for annealing? Can anybody help me!
metengr (Materials)
9 Jun 12 22:49
Annealing and stress relieving are not the same heat treatment. Annealing is performed at a higher temperature and the component is furance cooled. Stress relieving is performed at a lower temperature and the component can be air cooled.
I would suggest you look these terms up on the internet for more information.
patprimmer (Publican)
10 Jun 12 2:38
metengr
I presume you mean for metals only. Certainly some plastics and probably wood can be stress relieved by treatment in water.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
metengr (Materials)
10 Jun 12 9:47
Yes, I presumed the poster was referring to metals.
10 Jun 12 10:14
The material in question is a fairly important omission from the question.
Pat
for site rules
metengr (Materials)
10 Jun 12 13:43
patprimmer;
Yes indeed. They have posted a thread in another forum concerning cast iron and spheriodal cast iron and heat treatment. So, I believe this post was related.
10 Jun 12 18:56
Knowing that I agree but it would be really nice if the OP confirmed it, along with convincing us it is not a student homework post as it is a VERY elementary question. Of course there is one good explanation why a real working engineer might ask such an elementary question, but I would really like to hear from the OP in that regard.
Pat
for site rules
desertfox (Mechanical)
10 Jun 12 23:19
redpicker (Materials)
11 Jun 12 12:03
The problem is the terms "annealing" and "stress reliving" describe the desired result of the heat treatment, not the heat treatment itself. For one particular metal, a particular cycle could be considered an annealing cycle, while for another, the same heat treatment could be considered a stress reliving cycle. Still another, it could result in hardening of the material.
Sounds like homework.
rp
Metalhead97 (Materials)
18 Jun 12 11:05
Saravanankumarasamy,
Stress relieving as the name implies relies on a combination of heat and stress to produce solid diffusion that results in elastic stresses being relieved. Typically, depending on the state of stress these temperatures are well under the annealing temperature. For instance, I've been able to stress relieve fine wire at 375C in order to straighten it while the typical full annealing temperature was over 300C higher. Keep in mind that during stress relieving you will get some recovery, and in age hardening systems you can get a precipitation reaction depending on the kinetics.
MH
http://www.linkedin.com/pub/luke-autry/1b/510/566
18 Jun 12 22:27
Of course a crack developing can also relieve stress.
Pat
for site rules
19 Jun 12 11:33
Pat,
Yes, cracks are excellent at relieving stresses! Several years ago, a crack developed in my windshield after a rock hit it. Everybody pointed out that I had a crack, but I saw it as a stress relief.
MH
Close Box
Join Eng-Tips® Today!
Join Us             Close
