Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Brilliant! Your site is great...and saving me hours of time at work and making my boss think I am brilliant too! I also picked up on a thread that will potentially save us a lot of money in the future..."
Geography
kgengr (Structural)
8 Jun 12 18:41
Hello All,
I am designing an SCBF in SDC D. Per AISC Seismic Provisions (C8.5, 6.1-147) it seems clear that the connections of the column base to the foundation shall be designed for either the seismic loads with overstrength or loads based on member strengths, whichever were req'd/governed for the system connections. My question is with regard to the design of the foundation itself for overturning, bearing, and reinforcing. Should I be using the seismic design loads with overstrength or the same loads I used for my connection to the foundation - in my case, governed by loads based on member strengths? It seems to me this is not specifically addressed in any of the following codes: AISC, IBC, ASCE, or ACI.
Thanks for your help.
SteelPE (Structural)
8 Jun 12 18:52
I don't know what code you are using but isn't this handled is section 12.13 and 12.1.5 of ASCE 7-05? I would guess from these sections that you would design the foundations for the forces imparted on the structure..... and then take any reductions allowed in section 12.13.4. Please keep in mind that I generally design using R=3.
SethGuthrie (Civil/Environmental)
8 Jun 12 19:01
You don't need to design the footing (or check soil stress) at the amplified overstrength seismic level (exception Battered piles). You should check the foundation for combinations including Ev the vertical component of the earthquake, however.
kgengr (Structural)
8 Jun 12 19:07
This may be correct - but here's my line of thinking - if the SCBF is designed to dissipate energy by yielding at the foldline of the gusset plate, and all other detailing of members and connections has been done to "ensure" this will be the case, including anchorage to the foundation (for either overstrength or member capacity) - why then would the foundation itself be designed for the basic design level forces? It seems to fall short putting a massive connection and not the footings/foundations to support it...
Close Box
Join Eng-Tips® Today!
Join Us             Close
