Error with file
Error with file
Error with file
hi
I have a problem, when I print out a *.dwg cadR14 I review full and it have message "Fatal Error Unhandled Float Invalid Operation Exception at 7628bdh" .I try to open it in another computer it same trouble.But when I open and print another drawing it OK
I try to fix it with audit, recover, and purge but it not effect. Even I write it to block (wblock command) when I open this file it can not print ( I mean can open can modify but can not print)
Have you any problem like this? Help me
RE: Error with file
Dear cad123,
Try to insert the file into a new drawing in a coordinate rather than 0,0 .
Farzad
RE: Error with file
I try use another computer , it is ok.
Maybe conflit with my lisp routine
