API 2000# Flange vs. ANSI 600# Flange
Just thought I'd ask a quick question about a small discrepancy having to do with the bolt-up of an API 6A 2" 2000# flange with an ANSI B16.5 2" 600# flange.
I've taken it for granted in the past that the two mate up without issue. However, today a co-worker challenged me on it and stated that the bolt size required for each is slightly different. Sure enough, I went to my pipefitters handbook and the bolt size for the API flange is listed at 5/8" diameter whereas the ANSI flange has 3/4" diameter listed.
Anyone have any idea if this is an issue to be concerned about? Or can I just use the larger 3/4" bolt without issue?
OilsandsEng
RE: API 2000# Flange vs. ANSI 600# Flange
The 2-inch ANSI 600 flange calls for 0.75 inch bolthole, so getting a 3/4 inch bolt through might be a challenge. If it fits, it is no problem to use a heavier bolt than called for, but it doesn't have to fit.
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
