SW 2004 hotkeys not working
Searching and using solidworks help and tutorals are great ideas.
I ressurected a 2004 SW that we never used at my new company. I was a SW user for 8 years prior to starting here. The old version is fine for what I will use it for but I was accustomed to using hotkeys. I have set some of them and used the default ones but most of the time the hotkeys do not work, sproadically. Some keys work and some not, at different times. The hotkey setup dialog box is more basic than the later versions, that you can easily edit them and print. Any good ideas to improve this?
Thanks!
