designing PWM-motor interface for low EMI
Does anyone have any tips or links to info on designing a PWM interface for a DC motor in order to reduce EMI? I've got a tiny fan (less than 50mA current draw). I plan on driving it with a PWM output using a PNP transistor on the high-side. I figured that I would put a backwards diode across the motor. Anything else that I should consider? A capacitor? An RC snubber? Ferrite beads? Are these things bad sources of EMI or am I being overly cautious?
Thanks in advance.
Glenn
Thanks in advance.
Glenn
RE: designing PWM-motor interface for low EMI
A free-wheeling diode should be there also for other reasons (free-wheeling when transistor is off) and a ferrite bead or ring with both armature wires through it is always nice. And, to kill the brush noise, put a small capacitor across them.
Gunnar Englund
www.gke.org
Thanks for the info Gunnar!
Glenn
