Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...it was ingeniously designed and all those clicks were for my own good... and that was even before I got my speedy and useful answer to my tekkie question that I eventually posted..."
Geography
Inventor: new sketch cannot reference anything off previous sketches/features
KKerr23 (Mechanical)
8 Jun 12 8:56
Everytime I start a new sketch based off either the origin or a face of a previous sketch/feature, I cannot reference any point from it to base my next sketch on. Being that I am somewhat new to Inventor coming from SW I am curious to see if there is some way that this is possible since it is needed to draw up the rest of the portions of the part I am making. Any ideas on how to fix this? Bear in mind I am stuck with the 2009 version
mcgyvr (Mechanical)
8 Jun 12 10:01
tools..application options..sketch tab... check "autoproject edges for sketch creation and edit"
I also like "autoproject part origin on sketch create" to be checked also..in case its not
8 Jun 12 10:06
It was already checked off and I still cannot reference to any previous sketch... only edges from features which i had to do dimensions instead of snap points to line it up... and to make matters worse, Inventor cannot even loft a simple trapezoidal shape and all the constraints are in place
mflayler (Mechanical)
8 Jun 12 10:14
In Inventor you need to use Project Geometry to reference other sketch geometry. I normally do not turn on the project edges on sketch creation because when I dimension to it I can scrub the edge and it will automatically project anyway. I don't like making references to faces when the majority of the time I don't want them as a parent reference.
Inventor can loft a simple trapezodial shape, perhaps there is just a few new user missteps involved here. Attach your file if you want someone to take a look at what you have.
Close Box
Join Eng-Tips® Today!
Join Us             Close
