Flexible Diaphragms in RISA-3D Without RISA-Floor?
Is there any way to model (efficiently) a flexible diaphragm in RISA-3D without using RISA-Floor? I have finally forsaken portal method and moment distribution spreadsheets and purchased a copy of RISA-3D to join the 21st Century, only to realize that I might need additional software to do something as simple as a flexible diaphragm? I have no issue with getting RISA-Floor, but given the unreasonably short code cycles if I buy it I must maintain it. If RISA-3D can do the flexible diaphragms without too much non-sense I can probably get by for a few code cycles, otherwise it looks like I'll have another thick user's manual to read.
Mike
Mike
RE: Flexible Diaphragms in RISA-3D Without RISA-Floor?
1) You will have to adequately mesh the plate elements in order to get accurate results. Therefore, you will be spending a lot more time modeling the structure than if you ignored the diaphragm completely.
2) If you don't want the diaphragm to affect the plate elements, then you should make the plates weightless (i.e. set the density of the material to zero) and use the option for "plane stress" plates.... Though this may not be available on older versions of the program.
With some of the new analysis requirements (esp AISC's Direct Analysis Method), flexible diaphragms can lead to false stability issues (because the diaprhagm stiffness isn't modeled). That doesn't happen with the semi-rigid (or semi-flexible) diaphragm modeling using plate elements. But, it can happen whenever you use the idealized "flexible" diaprhagm assumptions... even when that diaphragm came from Floor.
RISA 3D now has the option to disconnect the diaphragm for no composite action.
