Removing "Name Only" references in clone
I'm stuck with a "problem" when cloning my assesmbly in teamcenter (or importing/exporting to tc/native).
The thing is that I've got references that I can't get rid of. These references doesn't exist as parts any longer, however they still lives on as "Name Only reference" when cloning. I can't find any relations to these parts anywhere in tc or native.
Any ideas how I could find and get rid of them?
NX6.0.5.3 MP1
Best regards
/Lars
NX6.0.5.3 MP1
Best regards
/Lars
RE: Removing "Name Only" references in clone
thread561-322890: Importing WAVE-linked parts into Teamcenter with a "reparent" part
perhaps it will help you.
www.nxjournaling.com
I've tried to use the part cleanup tools without any "luck" so hopefully there will be other methods.
/Lars
I presume that you have looked for interpart links (expressions and or geometry) already.
Make a new empty part file with the name of the Name Only Reference part. With that part already loaded in the NX session open the assembly part, add the Name only reference part as a component part, run part cleanup for the assembly then delete the component and finally save the assembly.
HTH, Joe
I tried your approach but still without any luck.
It ended up with me having to recreate/rebuild my (top) assembly to get rid of my problems.
Thank you guys for your effort!
/Lars
