vfd app.
vfd app.
Are there many problems using a vfd on a 460v 1 hp inverter duty motor that uses a slipring ?. Are there some concerns with this design ?. A good part of the work by motor is at 60 hz
RE: vfd app.
Also examine your need for variable speed. If it is for enery savings, running most of the time at full speed from a VFD will actually INCERASE your energy consumption because the VFD has losses.
"Dear future generations: Please accept our apologies. We were rolling drunk on petroleum."
— Kilgore Trout (via Kurt Vonnegut)
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
RE: vfd app.
RE: vfd app.
The issue there is going to be with any possible discontinuity of the slip ring power source, but most drives store a small amount of energy storage in the capacitors to be able to ride through any reasonable anomalies. Over sizing the drive might help a bit but I wouldn't get too excited about it. I've done VFDs on Whirley Cranes and on rail powered cranes, never had a problem.
RE: vfd app.
RE: vfd app.
http://www.eng-tips.com/viewthread.cfm?qid=317132
Lyle
