Cutting a Timber Beam
I am installing a timber beam to allow for the removal of a wall
The timber beam will support roof struts and hanging beams.
I need to cut the ends of the new beam at the supports to suit the roof pitch so I can physically fit the beam in
What are the rules as to how much of the end of the beam I am allowed to cut?
RE: Cutting a Timber Beam
Under the IBC/IRC for sawn lumber the NDS shear design should be followed. For GLB the AITC Technical Note 19 (a free download at www.aitc-glulam.org) should be followed.
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
It sounds from your post that you are not a structural engineer, and if that is so, you need to retain the services of such. When you cut back the end of a wood beam to fit under a sloping roof at the eave, there is generally not much capacity left. Maybe you need a steel beam.
Hate to say it, but it depends on the situation. If the beam is shear critical - none. If not, then a varying degree depending on the level of shear stress in the area of the cut.
As Hokie said, get a local structural engineer to help you.
Mike McCann
MMC Engineering
http://mmcengineering.tripod.com
thanks guys - sounds like i need to engage an engineer - was hoping there might of been standard rules to follow
