Help with splines
Help with splines
NX 7.5.5.4
I'm stuck with series of splines (created by somebody else) that are wayyyy to complicated. For example, the spline I'm currently looking at has over 450 segments. I know enough to know that it should take less than 50 segments, probably closer to 25.
Anybody know an easy method to change these these?
RE: Help with splines
Anyhow, 1) do an information - object and pick the spline, note degree and number of segments.
2) Insert - Curve - Fit Spline - then press the "Edit Spline" button in the bottom right - pick the spline - pick the first icon in dialog ( the dialog will then default into the number of segments that the last edit finalized on.. which probably changes the shape radically) enter remembered number of "existing" segments and try from there .
Tomas
What is the degree of the spline, and is it a studio spline?
www.nxjournaling.com
