Good morning We use ASPEN 7.3, a
Good morning
We use ASPEN 7.3, and we need to design a condenser for petrol unit, our customer, give all the inlet flow to the condenser (steam, nitrogen, hydrogen...), but I don't kwow , how we must to put the data, when he give only the gas nominal boiling point (NBP:88)(NBP:100)....
can you explain what is the solution for ASPEN, to include these data, in the software
RE: Good morning We use ASPEN 7.3, a
Has your customer given you stream compositions? Do you have the true vapor pressure (TVP) curve?
no , our customer give only the gas nominal boiling point, he didn't give the TVP
thanks
