Equivalent Length
Equivalent Length
Equivalent Length
Just a quick quesiton. I have been looking with no success for some values for the equivalent length of both iron unions and couplings. Sorry I can't be more specific but I hope someone can help.
Thank you.
RE: Equivalent Length
In my experience, there is no need to handle unions and couplings as an extra pressure drop. Just ignore them and add up the pipe lengths.
Good luck,
Latexman
The equivalent length method is a fluid flow pressure loss estimating method that does not purport to a high level of accuracy.
In addition, the effect of pressure drop through minor fittings is negligible when the ratio of pipeline length to pipe diameter is large.
For these reasons, the minor losses associated with items such as unions are generally ignored.
If in doubt and you have a lot of fittings etc just add a foot or 2 to the total head calculation.
Unions are pretty minor restriction; probably 60-70% recoverable anyway.
If it ain't broke, don't fix it. If it's not safe ... make it that way.
