heat flux(Damping power)
Hello everybody,
I'm simulating with Abaqus the damping power(Heat flux) of a rubber coupling.
The material is symmetric and normaly the temperature at the surface or the temperature distribution muss be symmetric. What is not the case for me.
Please could anyone just just how step by step using the yeoh-modell in Abaqus and with a hart rubber material in mm, how could I proceed with all the values to give and where. Or simply what should I check and correct.
I am really out of idea after three weeks trying without succes.
I would be very thankfull
Rom
Rom
