Other conduit sealing compounds?
I was posed the question by a manager this morning as to whether there were other, not water-activated, sealing compounds that could be used in the place of 'chico' water-mixed compound in sealing fittings for use in classified areas.
I seem to remember some discussion of these some years ago, but I see nothing on the market.
And help?
And help?
old field guy
RE: Other conduit sealing compounds?
On the other hand, certain boundary seals for Class I, Division 2 [501.15(B)(2)]aren’t required to be explosionproof (or listed).
As rbalex says, you have to get the sealing compound along with the sealing fitting. The fitting and compound are listed together as a system.
http://www1.crouse-hinds.com/crousehinds/newproduc...
