NX 7.5.5 Crashes often when I open another file
While opening a series of files the system just closes. With the message "NX Component has stopped working" I also get
*** EXCEPTION: Severe error 904 in line 161 of O:\ugnx755\ip4\src\syss\sm\ind\sm_init.c at Thu Jun 07 08:29:06 2012 Eastern Daylight Time
+++ Attempt to free already free block at &000000000040495B
in the syslog after the last file that fails.
Any ideas would be helpfull.
RE: NX 7.5.5 Crashes often when I open another file
www.nxjournaling.com
If it only affects 1 workstation, perhaps a reinstall of NX is in order. If it is a certain file or combination of files, perhaps they are corrupt.
Remove the part from the assembly structure and readd it fixed the error. I think the assembly loaded if I used Load No Components, then removed the component from the structure.
Ben Loosli
Can you please try UN-selecting "Use Partial Loading" under Load options.. I had similar problem like this. I hope this may help you.
Arvind A Jeevannavar
Mechanical Design Engineer
UG 7.5.5.4 & TC 8.3
CODE -->
