Designing a closed loop recirc cooling system
Hi all,
I'm doing a project right now which deals with designing a closed loop recirculating system using water to cool multiple components. However, this post will only deal with the fluids portion.
Below is the diagram of a very simplified system. Note that the areas marked red are 90 degree fittings with a given k (loss coefficient) value.
I am only given a supply pressure (P_supply) of 100 psi, the lengths of each of the sections (the lengths from dot to dot), the diameter of the pipes, the pipe material, and the temperature of the incoming fluid (water). The diameter of the pipes are all the same, so it's constant diameter. Also, assume that the system is on the same plane, so there is no height or elevation.
I am required to find:
- The pressure at P_return
- The volume flow rate (Q or V_dot)
- The k_component
When I was given this project, it seemed somewhat confusing, so I asked for help from the project advisor. Unfortunately, he didn't give me a clear answer and he's unavailable for the next few days so I cannot ask him any questions for the time being.
He just said that the volume flow rate does not have to be given and that there's a relation somewhere and told me to read up on Hydraulic Grade Lines. Also, he said to split the system up into sections, which are the areas between the red dots. This made me a bit confused because I was wondering how I would account for the 90 degree bends so that I can add the loss coefficients, K, into the total head loss.
I have done many problems regarding finding pressure difference, total headloss, etc., but I am totally lost when it comes to finding these many unknowns. I am doing this analysis in Excel as well.
If any of you can give me some tips on how to find or solve this, please let me know.
Thanks!
- The k_component
Thanks!
RE: Designing a closed loop recirc cooling system
What would you be doing, if you knew that you could not fail? Ans. Gov lobbyist.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
Good luck,
Latexman
Best regrads Morten
I will try to find a copy of Crane's No. 410 around here.
Thanks.
Good luck,
Latexman
Good luck,
Latexman
“The beautiful thing about learning is that no one can take it away from you.”
---B.B. King
http://waterhammer.hopout.com.au/
