Power System Study Software
Hi
Anyone know of a cheap (free) software package that can reliably calculate volt drops, fault current etc in medium voltage systems?
RE: Power System Study Software
Bussman fuse used to offer a package like that, I don't know if they still do or not.  It was very similar to SKM PowerTools but included a library for only Bussman devices.  You could add your own devices to the library, though.  I'd check with them and the other overcurrent device vendors.
Thanks for the advice, I will follow it up
Try elite softwares.
I have used the old Bussman programs.  It calculates fault current, but not voltage drop.  It is a good program if still available. It will handle more than one source and about 50 busses at medium and low vlotage.
Cutler Hammer had a graphics program that calculated fault current and voltage drop. It was not free however and I did not find it useful. Provided too many graphics errors and omissions.  Cuttler Hammer is promoting a new program but do not know anything about it.
I suggest you look at MikeHolt.com for fault calculation and voltage drop spred sheet programs.  These are probably in archives.
Thanks, Im downloading it now - will let you know
I used PSS/VIPER - you can get it free for 30 days from www.pssviper.com .
