NX7.5 text transfer from drg. to drg.
3
Hi All,
Is it possible to transfer a drg note from one drg sheet to another in Nx7.5, as it was in NX4 by simply clicking on the note which it would then remember and allow you to add that same note to a new drg.
Andy.
RE: NX7.5 text transfer from drg. to drg.
What I have done is simply use the text edit command, copy the text of the note, go to your other sheet, then use the the note command and paste.
Rock n Roll.
Thanks.
- i hope that you know that if you have text-files ( i.e xxx.txt) you can drag drop these onto a drawing .
( Sharp edges blah blah, tolerances according to .... etc etc.)
Tomas
Frequently used notes can also be saved as .tx files on a specific location and then be inserted in the Import/Export Field.
Best regards,
Pascal,
NX5.04+TC2007 (GM Toolkit) / NX7.5 native
