Patran Thermal
Patran Thermal
I need to project nodal thermal load of a part to a similar one which is only offset. For that i try to create a spatial field(thermal) by the FEM method. The definition is continuous, and i need to create a scalar field type, for using it to create a thermal load("Loads/BC") on a different part. In option, i choose an interpolation by an axis. My problem is that i can't choose a group (content with my part and its thermal nodal load) to create the field. In fact the "Mesh/Results Group Filter" is empty. Does any one know why? And otherwise, have you got others method to project nodal thermal load?
Thanks for your help!!!
