Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...The forum looks great! You guys have done a fantastic job on arranging things there...Your site is very precise and fun to visit..."
Geography
smallboatguy (Marine/Ocean)
6 Jun 12 4:26
Hello all, my first post here. Lantour is located over seas and I cannot seem to get them to respond in regards to Soric 3mil LRC flexible core. I am infusing a part now (have been) with an 0/+45/-45 22oz with a .75ov cont veil stiched to it, on top of a 1.5oz layer of cont mat, and a typical 20mil gel coat, and .75oz skin coat. I want to switch the procedure to a no skin coat infusion with epoxy (we are using a VE from Cooks) and use the LRC as a core and layers of cloth 2oz as print barrier/10oz/LRC/10oz However I have no experience or data on these. Does anyone have data on soric panels ? Thank you
6 Jun 12 4:32
I wanted to add we are currently using glass rienforcements, and I assumed everyone would know this...sorry. Also I will add the cloth I mentioned switching too will be glass also with possible aramid/carbon spot reinforcing in certain areas. This is a small boat we currently build that we have redesigned and are trying to drastically reduce weight on without going to a carbon hull.
berkshire (Aeronautics)
6 Jun 12 19:47
Have you checked other brands of core mat?
From your post, I gather that you are not doing a core mat yet , but would like to.
B.E.
The good engineer does not need to memorize every formula; he just needs to know where he can find them when he needs them. Old professor
6 Jun 12 21:13
I do not want to use 'coremat' as i am infusing the laminate- I have not checked out any other materials as I am pretty set on using the LRC as other simular makes of boats have had success
6 Jun 12 21:44
Vanguard industies have used it with success, However bear in mind that LRC is a micro balloon/glass sphere loaded mat, with a honeycomb pattern pre wetted into it to prevent excess resin wet out. I was using the term core mat as generic term not as a brand name. Soric is based in Holland I am presuming that if you are using Cook Paint and Varnish products you are in the USA. If that is the case bear in mind that they are between 6 and 9 hours ahead of you.
B.E.
Close Box
Join Eng-Tips® Today!
Join Us             Close
