Spring element between two RP
Guys, I've got two parts and want to connect them together using a spring element. I've done following:
1- Create two RP for the two parts
2- Couple each RP to its relevant part
3- Connecting two RP using an spring element
when I run the model using explicit solver I get following error:
"Spring elements in element set ErrElemSpringsWithoutMass-Step1 are connected to massless nodes."
Does anyone knows what is the problem?
RE: Spring element between two RP
obviously I don't want to connect the the spring directly to a node on the body as I believe it causes local effect on the body. is it right?
