Hydraulic Cylinder Adjustable endstop
Hey there. I am putting it out there if anyone has a design idea. What we have is a double ended hyrdaulic cylinder used to endform a tube. The problem is we have different lengths of tubes that need to be changed over a lot. We currently use a mild steel tube put around the back rod of the cylinder and it is used as a dead stop... to stop the cylinder from forming any further therefore controlling the final length of the tube. Any ideas for an adjustable one for easy changeover??
RE: Hydraulic Cylinder Adjustable endstop
Introduces an opportunity for mistakes.
Introduces am amount of variation each time you make an adjustment.
Your current system of fixed-length tubes seems better. Look for opportunities to make changing them faster.
Make them "C" shaped so they can be slipped on? Use a quick-release pin instead of whatever holds them on now?
Would this cylinder be what I'm looking for?
That cylinder has a position encoder on it. So it could tell a controller the stroke, then the controller tells a valve to close and the cylinder could stop.
But you probably don't have a controller now.
