Blow molding tolerances
I usually use DIN16901 as a reference for giving tolerances to injection molded parts. But recently, I've been given a part that is to be blow molded. I'm wondering if there is a similar set of standards or guidelines for blow-molding tolerances?
RE: Blow molding tolerances
Blow molders just give you a blank stare when you mention tolerances.
Mike Halloran
Pembroke Pines, FL, USA
